create line from x-y graph live data
I am sweeping from -1000V to 1000V I am getting a characteristic curve I(V), I need the slope of the middle part of my curve. I can do it on a signal graph but not on a x-y graph. I need to do it on the x-y so I won’t loose the voltage values.
Anyone can help me create a line from 2 specific points from a live measurement on a x-y graph?
Gaudier
(3,758 Views)
Maybe you could do something along the lines of my earlier example. It does a linear regression of all points on an xy graph between two cursors.
(3,751 Views)
I already tried that, the problem is that I am taking 1 measurement per millimeter for 100 points in about 3 minutes and when I tried using cursors to create my lines they go crazy on  next measurement and  before  I could set them right  the next measurement is on.  On the attached vi I have what I need on a I vs.V graph but on the waveform graph.
Can I do what I’m doing on the waveform on a x-y?
Gaudier
(3,723 Views)
You can read the first 500 points of this sample so you can see the shape of my curve.
(3,719 Views)
Do you want the slope of the steepest part in the center? This is only a few points and won't be accurate because you also seem to have some oscillations in the data.
  • Maybe you can filter it and take the derivative, then just find the max?
  • How about fitting the entire central part to a sigmoidal function with a polynomial background, for example.
(3,708 Views)
