How do you deactivate a license on a failed computer?
I have a computer that suffered a hardware failure that has a licensed copy of LabVIEW 8.6. I would like to deactivated that machine and install the software on another working machine. How do I do that?
(5,896 Views)
Zia
What I have done in the past is - request support at http://sine.ni.com/apps/utf8/niae_asc.main
Visualize the Solution
CLA
LabVIEW, LabVIEW FPGA
(5,893 Views)
Hello Zia,
You can use NI's License  Manager software to deactivate a license.
Open License Manager, found in the National Instruments startup directory.
Expand the tree on the left hand side to expose the item you wish to deactivate.
Right click, and deactivate.
*edit*   In the case of hardware that has failed, you should be able to just go ahead and re-license on a new machine.  However it couldn't hurt to send an email to NI Support indicating that you have done so.
Message Edited by pallen on 02-26-2010 03:18 PM
Patrick Allen: FunctionalityUnlimited.ca
(5,859 Views)
Accepted by zia
Patrick, it sounds like he has had a system crash, so I don't know that it will be possible for him to use the normal software.
Putnam
Certified LabVIEW Developer
LabVIEW Champion
(5,857 Views)
