How do you disable scrolling in LV front panel?
Is there a way to programmatically or through LV's front panel properties menu disable scrolling of an active VI?  There doesn't appear to be any selections for this in invoke or property nodes.
(5,441 Views)
Accepted by btram
VI Properties > Window Appearance > Customize > Show Vertical/Horizontal scrollbar
Tim Elsey
Certified LabVIEW Architect
(5,435 Views)
You can customize the Window Appearance through VI properties, don't know if those methods are exposed for programmatic use.
(5,434 Views)
Thanks!  Would be great to have this funtion programmatically.
(5,429 Views)
They are a property of the pane.
Message Edited by Ravens Fan on 08-12-2009 11:24 PM
(5,401 Views)
