How do you easily relink VI to an extended COM server?
I have a VI that uses automation open/close to access properties and methods of a COM DLL.  I recently extended (i.e. no properties or methods were changed or deleted, only added) the COM DLL and the VI broke.  When I click on a property node or an invoke method node it says there are no methods or properties.  If I remove all the wires and rewire the whole thing it seems to work again.  Is there anyway to avoid rewiring the entire VI every time you extend the COM DLL?
(2,376 Views)
I believe that you should also be able to relink the property node by right-clicking it and navigating to the same COM class again. Unfortunately, there is not to my knowledge a one-click solution that will relink all property nodes. It would be worth submitting a product suggestion on, though, and I've included a link to do that here.
Kind Regards,
E. Sulzer
Applications Engineer
(2,358 Views)
