How do you find the pallet a function belongs to?
If you read about a function and want to use it, how do you find the pallet a function belongs to?  I know how to search for a function, but that doesn't tell me how to find its pallet.
Thanks in advance.
(3,893 Views)
A easy way.
Select the function and press ctl+h
Message Edited by Baji on 06-08-2009 05:57 PM
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
(3,888 Views)
Hi Joe,
the path to the example in the advaned help should give this information.
Mike
(3,886 Views)
Accepted by VI_Joe
When  you search for a function and double click the result, it will bring up the functions palette tree and show you how to get to that function:
search
Misha
(3,838 Views)
mishkin i forget it. ya its a easy method find the functional palette tre for the searched functions.
Balaji PK (CLA)
(3,821 Views)
