How do you find the pallet a function belongs to?
If you read about a function and want to use it, how do you find the pallet a function belongs to?  I know how to search for a function, but that doesn't tell me how to find its pallet.
Thanks in advance.
(3,892 Views)
A easy way.
Select the function and press ctl+h
Message Edited by Baji on 06-08-2009 05:57 PM
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
(3,887 Views)
Hi Joe,
the path to the example in the advaned help should give this information.
Mike
(3,885 Views)
Accepted by topic author VI_Joe
When  you search for a function and double click the result, it will bring up the functions palette tree and show you how to get to that function:
search
Misha
(3,837 Views)
mishkin i forget it. ya its a easy method find the functional palette tre for the searched functions.
Balaji PK (CLA)
(3,820 Views)
