How do you generate an executable in LabVIEW 8.6?
How do you  generate an executable in LabVIEW 8.6?  A point to a web site would be helpful.
Thanks in advance.
(3,356 Views)
 Hi
This tutorial will help you in creating executables.
http://zone.ni.com/reference/en-XX/help/371361E-01/lvhowto/exe_ex/
http://zone.ni.com/devzone/cda/tut/p/id/3303
http://digital.ni.com/public.nsf/websearch/993DBBC71F2C75FD86256ABF0061820E?OpenDocument
Anil
Anil Punnam
CLD
LV 2012, TestStand 4.2..........
(3,352 Views)
In version 8.0 and above you must create a LV project first.  Once you have created a project you can right click on build specifications located at the bottom of the project window.  Select new>>application.  This will allow you to create the exe.  If you want to create an installer then you must follow the same process.  They are now separate.
To find more information goto the help menu in a LV window and select "search the LabVIEW help"  When the window pops up select the index tab and type the following: "building, applications (how-to)"  This should give you the information you need.
Hope this helps.
BJD1613
Lead Test Tools Development Engineer
Philips Respironics
Certified LV Architect / Instructor
(3,351 Views)
Thanks in advance.
The manual is also quite helpful.
(3,348 Views)
I aslo think it is a converter in LV 8.x for converting old .bld files. But this conversion is not 100%
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,335 Views)
