Trouble setting up traditional DAQ in LabVIEW 8.6
I am having trouble setting up traditional DAQ in LabVIEW 8.6.  I downloaded version 6.9.3 of traditional DAQ from http://joule.ni.com/nidu/cds/fn/p/sn/n23:3478.41.181.1130/lang/en and then tried to install.  When I did, I got the following error messages.
1. You have a higher version of NI DAQ provider for MAX.  You must uninstall it before installing NI Provider for MAX.
2. Error 1603 occurred while installing NI DAQ Provider for MAX.
3. Error 1605 occurred while installing NI-PAL 1.56f0 Engine.
I couldn't figure out how to uninstall NI Provider for MAX and wasn't sure I really wanted to.  In conclusion, I was unable  to install traditional DAQ.  Any ideas?
Thanks in advance.
(3,011 Views)
Did u try installing Traditional-DAQ using the drivers DVD that came with LabVIEW 8.6 software?
If you want to setup Traditional DAQ, that would be the best option i believe...
Anil
Anil Punnam
CLD
LV 2012, TestStand 4.2..........
(3,004 Views)
I was just reading my "DAQ Getting Started Guide" that came with my data acquisition card.  It says "Do not install NI-DAQmx if your existing applications include unsupported components ...".  I think this may be the problem.  I want to upgrade an application that was written in LabVIEW 4.1 using Traditional DAQ.  However, DAQmx drivers have been loaded on the computer.  How do I go about uninstalling DAQmx drivers?
(2,991 Views)
you can go to
COntrol Panel-->Add/Remove Programs
Select national instruments
click on change.
then select NI-DAQ mx option and click "remove" button...
and follow instrctuctions  on the screen...
Anil Punnam
CLD
(2,984 Views)
I am running Lv 8.x and NIdaq 6.9.3 and it works fine. No problem at all. Bur read this http://digital.ni.com/public.nsf/allkb/F185E098C7EC5A3486256D2E00691BB2?OpenDocument
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(2,980 Views)
