How do you get the default value of a typedef from the path?
I know I can obtain a reference to a typedef by using the Open VI Reference primitive. However, if I get the Front Panel>>Controls[1]>>Value property, the variant I get is not a typedef. How do I get the default value variant from the .ctl path?
(3,598 Views)
I didn't know you could do this, so I thank you for pointing this out. What you described worked for me for an enum. Make sure your default value actually returns something. For my enum the variant looked blank at first because the first value in the enum was a blank string. Hope this code snippet helps:
_____________
Creator of the BundleMagic plugin for LabVIEW!
(3,580 Views)
Be sure and pass error wires between those functions, and close the reference you opened when you are done or you will have memory leaks.
(3,568 Views)
Um, deleted already this demo, but thanks. Smiley Indifferent
_____________
(3,562 Views)
The variant is the value of the control sitting inside the typedef. It is not a typedef itself. To get the value, you could do something similar to what I describe in this idea. Just get the value property instead.
(3,553 Views)
altenbach,
I know how to get the value of the control on the front panel, but I want to get a variant of the typedef from the .ctl path. Maybe it isn't possible.
(3,542 Views)
I don't have a development environment available right now, but you may be able to create a reference to the control with scripting.
There might be something in vi.lib\Utility\VariantDataType that can get a default value
Lastly, would a class suit your needs? Loading a class into memory from file is a well documented process
_____________________________
- Cheers, Ed
(3,522 Views)
