How do you input current time into a graph?
I have data that will be inputed onto my computer via hardware but how do I get it to plot against time?
Cheers
Message 1 of 8
(4,293 Views)
Hi ssteel,
If you are using waveform then build waveform with input current time.
It is as follows in ex.
Shrek
Message 2 of 8
(4,290 Views)
The Charts and Graphs always polt against time. The time base is just a factor of how often you are sampling. If you are sampling once per second, then the ticks on the X scale represent seconds.
Richard
Message 3 of 8
(4,268 Views)
Building on what Broken Arrow just said, once you have time on the x-axis,
you can right-click the axis, then go to  format.
You can then change the time to absolute or relative, as well as how the time is formatted.
Message Edited by Cory K on 08-04-2009 09:55 AM
Cory K
Message 4 of 8
(4,263 Views)
Cheers,
My input is numbers that im getting from I/O Assistant, how do I hook that up to the build waveform since it needs a brown connection rather than orange?
Message 5 of 8
(4,238 Views)
Accepted by ssteel
Are you getting one data point at a time, or an array of data points?
If you are getting an array, you can use Build Waveform in the Waveform palette.  Feed the array into Y, your delta T into dt, and your start time into T0.
You can also write an offset and multiplier (basically T0 and dt) into the X scale property nodes for the chart or graph.
Message 6 of 8
(4,200 Views)
Hello!!
Could i have a sample of the Ex.vi in version 8.5?
i couldn't open it in 8.6. Thanks! =D
Best Regards,
KK
Message 7 of 8
(3,982 Views)
It is small enough you can easily recreate in LV 8.5.
Message Edited by Ravens Fan on 01-21-2010 10:01 AM
Message 8 of 8
(3,951 Views)
