How do you make a 3 position toggle switch and 4 position dial?
NI has a demo on how to make a 3 position switch on their website, unfortunately it is in LabVIEW 8.6 and I am unable to open it with 2011. Is there a more updated version of this example, or anywhere I can find detailed instructions on how to do this? I am new to LabVIEW, so the more detailed the better.
Nate
(9,147 Views)
Why do you say you can't open it?  LV 2011 can open LV 8.6 files just fine.
Post a link.
(9,144 Views)
Don't know, I thought so too. I just get the error, LabVIEW load error code 10: VI version (5.0.1) is too old to convert to the current LabVIEW version (11.0). So maybe this is actually older than 8.6?
(9,142 Views)
Yes,  It is older.  It is version 5.0 like the message says.  I'm not sure why you thought it was 8.6.
Searching the forums for "3 way switch" yielded this thread. http://forums.ni.com/t5/LabVIEW/3-way-vertical-toggle-switch/m-p/219368
(9,140 Views)
To answer the second question:
To make a four position dial, place a regular dial and change the representation to integer (e.g.  I32). Adjust the scale range so only four positions show.
(9,128 Views)
Have you had any luck with that 3-pos toggle switch? I'm using LabVIEW 10 (which also can't open a LabVIEW 5 file).
(9,062 Views)
Follow the link in thee reply from Ravens Fan.
NOTE: (How the heck do you write that possesive? "Ravens Fan's" just doesn't sound right.)
(9,049 Views)
