How do you modify an array element and returning the result to the source array.
I am using 'Replace Array Subset' which wants to put the modified value into an output array... not the same one that was the source array.
(2,858 Views)
The array in the wire is the one that has been modified, subsequent operations on the wire will use the modified array. If subsequent iteration of a repetative loop need the data, put it into a shift register. If you need to update the original front panel control use a local varaible to the control.
Stu
(2,858 Views)
