How do you normalize waveform so maximum is 1.00 and its minimum is 0?
I have found the normalize waveform function, but it normalizes the waveform so the maximum is 1 and the minimum is -1. There doesn't seem to be any way to change the maximum and minimum of the function, but I really need the minimum to be 0. What should I do?
(3,257 Views)
Accepted by topic author DaniMor
After you have normalized for -1 to 1 ... then divide by 2 and add 0.5.
http://www.medicollector.com
(3,247 Views)
Such a simple solution evaded me, thank you.
(3,237 Views)
