how to plot XY graph with values from DAQ and motor counts from its controller
I'am using a DAQ to measure analog signals with a motor with its controller giving the motor counts . I need the variation in intensity of DAQ signal with the motor counts. I had converted the motor counts into number using the converter and then put it to the build XY graph VI in labview 2011. I had done the same thing using the DAQ. I put the DAQ output to the Build XY graph VI . Butfinally graph is not drawn is it a problem with the bundling of data from DAQ.please help me I'am attaching the VI with this
(4,378 Views)
Could you post a LabVIEW 2010 version of your VI?
-CC
"If anyone needs me, I'll be in the Angry Dome!"
(4,353 Views)
You are resetting the XY graph each time you call it. Please look at how you have configured it.
Also, do not do a VISA Configure Serial Port and a VISA Close inside the loop. And, since I doubt that the string to write is *IDN?, make it a constant and use the correct command. You are also acquiring 1000 samples with the DAQ Assistant but only one with the serial read. Why?
(4,350 Views)
Perhaps you only want one number from the com port number and one analog voltage per loop.
Here's a snippet that shows Build Array and Shift Registers. It is only a starting point, though.
Perhaps change your express VI to only take one sample.
There is a good XY Graph.vi in the Example Finder.
(4,335 Views)
Todd,
Just fyi, the express xy graph in the op's last modification has an internal **bleep** register. As long as reset is not true, it will append.
(4,325 Views)
Thank you, Dennis.
Somehow I've missed the glory of the express vi's.
(4,309 Views)
I guess a typo caused the bleep because I intended to write 'shift' register.Smiley Very Happy
In any case, I looked again at the block diagram of the express graph and my memory was wrong. It does not use a shift register. It uses a local to keep a history of the graph.
(4,306 Views)
