Posted this in Hardware-->Machine Vision and got no response, so now trying here...
System: Windows XP Pro Labview 8.01 Vision Development Module 8.0
When
you have an IMAQ Image Display Control, you can add multiple ROI areas
by using the "ctrl" button and drawing new regions. On the
developement machine of LabVIEW, you can selectively delete individual
ROI contours by right clicking on it and selecting "Delete ROI Contour"
from the shortcut menu. You can also "Clear ROI", and "Save Image..."
on the development machine. These functions are great!
This is the problem: When built as an executable these items do not show up in the right-click shortcut menu! Programatically
adding custom runtime shortcut menu or buttons to "Clear ROI" or "Save
Image" is easy, but I don't see any way to programatically determine
the currently selected ROI so that I can delete it. Are there are no
properties visible that indicate this? I can see how to use the "Last
Mouse Postion" and delete and ROI that bounds the mouse position, but
this will not work for complicated ROI's.
Were these shortcut items left out of the EXE intentionally? Is there some way to get this funtionality back in the EXE?
