How do you use Double-click in a list box in 6i?
I am having problems using the double-click from a list box in labview 6i. It just stays at -1 for a value. Never changes. I used the one in 5.0 but it doesn't work in 6i.
(2,868 Views)
I just tried it and it is working for me. As soon as you read the property "Double-Click" it resets to -1 on the next read. You will only be able to read the "Double-Click" once.
-Jim
(2,868 Views)
I too had the same problem. I copied your solution into my application and it does not work. I am having a difficult time figuring out why this is the case. Take a look at my file and if you have any suggestion I would be grateful.
(2,868 Views)
I created a reference to the Test Choice list box and it seems to read
DoubleClick OK .
I don't know why it won't work as a simple property node.
test_flow2.vi attached.
"Paul Calvert" wrote in message
news:506500000005000000D5290000-986697009000@quiq.com...
(2,868 Views)
