How do you use custome icons with listbox
@scmm wrote:
Please can you suggest me a work around or a different indicator type to have names on the left side and symbols on the right side?
If you are willing to modify your INI file and read through a thread at this site, there is a workaround. Basically, the workaround allows glyphs in multiple columns. For your case, no glyph in the first column and then a glyph in the second column. You will still have listbox functionality also.
mcduff
Message 11 of 11
(446 Views)
