How do yuo bundle discrete tasks into a single task
I have several discrete tasks defined using NI Max.  How do I bundle them together in LabVIEW as a single task?  I don't want to use NI Max to create the compound task.  I want to do it programatically so I can pick the discrete tasks I want.
(3,892 Views)
Should work fine
(3,886 Views)
Thanks, but where do I find (and what is)  the Vi between the for loop and the create task VI?  I cannot find it on the palette.  I'm running 2014.
(3,829 Views)
DAQmx Flatten Channel String (VI) <script type="text/javascript">// var L_helpType = "STD_ENG"; // </script> <script type="text/javascript">// var L_taskconfigchm = "taskconfig.chm"; // </script> <script type="text/javascript">// var nofeedbacklink = true; // </script> <script src="/t5/forums/replypage/board-id/170/message-id/common.js" type="text/javascript"></script> <script src="/t5/forums/replypage/board-id/170/message-id/jquery-1.7.2.min.js" type="text/javascript"></script> <script src="/t5/forums/replypage/board-id/170/message-id/cssframes.js" type="text/javascript"></script> <script src="/t5/forums/replypage/board-id/170/message-id/domtools.js" type="text/javascript"></script> <script src="/t5/forums/replypage/board-id/170/message-id/arraytools.js" type="text/javascript"></script> <script src="/t5/forums/replypage/board-id/170/message-id/initpagedyn.js" type="text/javascript"></script> <script src="/t5/forums/replypage/board-id/170/message-id/stylesheets.js" type="text/javascript"></script> <script src="/t5/forums/replypage/board-id/170/message-id/web.js" type="text/javascript"></script> <script src="/t5/forums/replypage/board-id/170/message-id/pdf.js" type="text/javascript"></script> <script src="/t5/forums/replypage/board-id/170/message-id/infocodes.js" type="text/javascript"></script> <script src="/t5/forums/replypage/board-id/170/message-id/launchhelpLV.js" type="text/javascript"></script> <script src="/t5/forums/replypage/board-id/170/message-id/launchdaqhelp.js" type="text/javascript"></script> <script src="MS-ITS:glang.chm::/helpserver.js" type="text/javascript"></script> <script src="/t5/forums/replypage/board-id/170/message-id/Variables.js"></script> <script src="/t5/forums/replypage/board-id/170/message-id/cssframes.js" type="text/javascript"></script> <script src="/t5/forums/replypage/board-id/170/message-id/launchhelplv.js" type="text/javascript"></script>
Owning Palette: DAQmx Utilities VIs
Installed With: NI-DAQmx
Converts an array of physical or virtual channel names to a comma-delimited list of names. You can use this VI to convert an array of channel names to a single string prior to using the DAQmx Create Virtual Channel VI or the DAQmx Create Task VI.
(3,812 Views)
All that you needed to do was drag the snippet to your block diagram.
(3,803 Views)
Thanks.  I though it was just an image.  It didn't occur to me to try to copy it.
(3,795 Views)
