Cannont run executables in Windows 8
This problem has been probably solved, but I could not find a thread in this forum to explain whats the solution to the below problem:
We have developed a software pacakge in LabView 2012 SP1. The installation works fine in all versions of Windows from (XP 32Bits to 764Bits Pro), However after installing the softwrae in a new machine with Windows 8 32Bit (this PC used to have Win7 and used to run the software just fine) I get the following message:
" the vi is not executable the full development " (multiple times in a single dialog).
Any clues how to fix this?
Should I upgrade my LabView or is this just as easy as changing couple of checkboxes in project settings? Also, I dont care how big my installer will be as long as it will run on the new machine.
Thanks for you help and looking forward for your tips!
(3,222 Views)
After installing labview (2012 SP1) itself, the program started to work. So which version or what type of runtime engine or NI development package should I install on target computers to make the software work?
(3,197 Views)
BTW, for some reason I am not able to edit my original post up there, the error Im getting is:
"The VI is not executable. The full development version of LabVIEW is required to fix the errors."
I have seen this TThread but I think it is a separate issue!
Thanks in advance
(3,193 Views)
Accepted by topic author Hatefk
I resolved the root of the issue!
Its about having an older versoin of MS .Net Fx installed!
(LV needs 2.0 and 3.5 which the software installs it itself but win 8 only comes with 4.5 enabled.)
This page describes how to turn on/off windows features:
http://windows.microsoft.com/en-ca/windows-8/net-framework-windows-8
Thanks everyone!
(3,132 Views)
