How does labview use nce files
I have been using MAX sometime ago but did not make full use of it.
- How can I use labview to communicate with nce files?
- Does Labview communicate with MAX?
And I cannot find the document knowledge base to using MAX?
Only I can find in the help files but not enough. I need more info,
regards,
Clement
(4,672 Views)
There are several daqMX and MAX vis in labview for some communication with max.  Most notable you can save channels and scales to max under the advanced daqmx functions.  I have not played with this too much.  I am curently using daqmx 8.6 AND lv 8.5.  I think this is a relativle new feature.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(4,653 Views)
astroboy,
Starting with LabVIEW 8.0 you can import/export your MAX configurations (*.nce files).  Please refer to this knowledge base for more information.
What other things are you looking to do with MAX programmatically through LabVIEW?
Ryan N
Application Engineer
ni.com/support
(4,635 Views)
 Hi Falkpl Thanks I will have to look at DAQmx vi examples using MAX.
Hi Ryan, I have problem. I do not have a clue to error -200284.
see the attached. I am using Labview 7.1 and Max 4.2.1 amd using PCI 6220.
When I run the test, acquires signals but in the end it produces error -200284. Is this normal?
But when I run the test withthe came nce file in MAX, It produces no errors
Pls advise. Thanks
(4,618 Views)
Sorry forget to add my attached. and my wrong spelling
But when I run the test with the same nce file in MAX, It produces no errors
Clement
(4,616 Views)
astroboy,
Here is a knowledge base article discussing the possible reasons for your error.
Also, try and start with some of our shipping examples.  After importing your MAX configuration I used Cont Acq&Graph Voltage-Int Clk.vi and everything ran just fine.  You can get to this example by going to Help>Find Examples.  Then go to Hardware Input and Output > DAQmx > Analog Measurment > Voltage.
Ryan N
ni.com/support
(4,590 Views)
