03-23-2008 10:31 PM
03-24-2008 07:59 AM
03-24-2008
03:28 PM
- last edited on
09-21-2026
08:13 AM
by
Content Cleaner
astroboy,
Starting with LabVIEW 8.0 you can import/export your MAX configurations (*.nce files).
What other things are you looking to do with MAX programmatically through LabVIEW?
03-24-2008 08:56 PM
Hi Falkpl Thanks I will have to look at DAQmx vi examples using MAX.
Hi Ryan, I have problem. I do not have a clue to error -200284.
see the attached. I am using Labview 7.1 and Max 4.2.1 amd using PCI 6220.
When I run the test, acquires signals but in the end it produces error -200284. Is this normal?
But when I run the test withthe came nce file in MAX, It produces no errors
Pls advise. Thanks
03-24-2008 09:00 PM
03-25-2008
02:53 PM
- last edited on
09-30-2026
02:35 PM
by
Content Cleaner
astroboy,
Here is a knowledgebase article discussing the possible reasons for your error.
Also, try and start with some of our shipping examples. After importing your MAX configuration I used Cont Acq&Graph Voltage-Int Clk.vi and everything ran just fine. You can get to this example by going to Help>Find Examples. Then go to Hardware Input and Output > DAQmx > Analog Measurment > Voltage.
