How does my first FPGA VI look?
Just wondering if this is a good, efficient vi for what I'm trying to do. I'm reading values from an NI 9244 c-series module. 3 separate analog inputs and getting the RMS voltage of each. The only other way I thought to do it was to put all 3 into the same loop, and to be honest I have no idea which one would be better. I'm kinda just guessing right now.
(1,727 Views)
Accepted by topic author David99999
I would put them all in a single loop.  It would only require 1 delay.  You could also expand the IO node to read all 3 AI in a single node.
(1,700 Views)
Oh duh! I forgot about expanding the node. Thank you!
(1,667 Views)
