How i can generate report for NI EVS platform ?
(2,543 Views)
Hi amgad,
I wanted to clarify your question, what kind of report are you looking to generate with the NI-EVS platform?  Please let me know so I can better support your question.  Thanks!
Matt S.
Industrial Communications Product Support Engineer
(2,521 Views)
Excel Report like the reports that generated from report generation toolkit
(2,505 Views)
Hi amgad,
Yes you should be able to create reports using the EVS platform.  You can configure it in LabVIEW so you can use the report generation toolkit or these other methods:
The NI TDMS File Format
https://www.ni.com/en/support/documentation/supplemental/06/the-ni-tdms-file-format.html
Write To Spreadsheet File VI
http://zone.ni.com/reference/en-XX/help/371361J-01/glang/write_to_spreadsheet_file/
Matt S.
(2,492 Views)
