How i can i give differential output from sbrio
i want to connect relay at the output of the sbRIO for switching
i gave a  (0-7) voltage for 5volt relay from ANALOG OUT and ANALOG OUT GROUND
but relay is not switching
i tried with a mobile battery  3.7volt it is switching and i found it happened  when i connected -ve and +ve terminals of the battery with the relay
(2,751 Views)
Which sbRIO model do you have?
How much current does the relay draw?
(2,736 Views)
i am using sbRIO model number  9642
i have relays  of 12 volt (current 0.0375A) and 5 volt( current 0.072 A)..
(2,726 Views)
