How i can insert symbol of infinity or resistance by labview into excel file
Hi. i need insert infinity synbol into report excel file. how can i do this easly, maybe you have ready function for this target.
(4,941 Views)
Accepted by Denmal
If you don't want to get into EXCEL class & its propert node, then simplest way is to RECORD the macro of inserting symbolin EXCEL.
The copy the generated VB code & use it in LABVIEW by using EXCEL MACRO VIs.
(4,880 Views)
Since u accepted it as solution, did it help u?
Kudos are welcomed.
(4,871 Views)
i need try. i hope it's really solution. thanks
(4,870 Views)
