How many times a word appears in a text?
Hello, I have googled and searched the forum, but I can't find anything to get my code right. I want to search a .txt file and see how many times a keyword appears on demand. I've tried using a loop with the match pattern function, but I'm not getting the correct results. I appreciate any help given.search vi.png
Message 1 of 13
(3,417 Views)
Accepted by topic author Net2022
You need to wire up the shift register to the "start index" input on the Match Pattern.
Personally, I would just use the Search And Replace String, setting the "replace all" to TRUE and then just use the "Number Of Replacements" output.
GCentral
Message 2 of 13
(3,408 Views)
Try this:
Honestly, crossrulz solution above is much better.
=== Engineer Ambiguously ===
Message 3 of 13
(3,404 Views)
One unpleasant complication is figuring out what delimits a word.
Message 4 of 13
(3,386 Views)
Irrelevant, the program searches for an exact match and returns how many time that exact match was found.
Message 5 of 13
(3,382 Views)
I agree that the problem is much more complicated, because there are plenty of delimiters (space, tab, period, linefeed, double-quote, numbers, etc.) so it is important to only use consecutive strings from the correct lexical class. Just searching for a substring will give you plenty of false positives (e.g. searching for "trust" would also count the substring in "trustworthy" as a "word", etc.). You also need to ignore upper/lowercase.
Still, this is a simple homework problem to solve. Try it!
Some comments to the original code:
  • No, it is not OK to spin the outer loop millions of times per second, redlining one CPU core and heating your computer.
  • NO, it is not OK to place a wait inside the inner loop. Searching should progress as fast as possible (seconds, not hours for long files!)
  • Please don't maximize the front panel and diagram to the screen! (during debugging you need to see both, as well as the help windows!)
  • The indicator you call "frequency" has the wrong representation and does not display a frequency at all.
  • Your inner loop always finds the same word forever and will never stop unless the word exists zero times.
  • Since the keyword control should be constant during the inner loop, it belongs outside it.
  • Why do you have a shift register is you don't even look at its output?
  • etc.
Message 6 of 13
(3,378 Views)
Certainly not irrelevant.  Suppose the text contains " forum ", and you search for the word "rum" without regard for delimiters; you would get a match there in "forum".  But that is not the word "rum" and shouldn't be counted as such.
Message 7 of 13
(3,377 Views)
And you have to make sure that words at the beginning and end don't get missed for lack of a delimiter on one side.
Message 8 of 13
(3,371 Views)
Oh, good point... I hadn't thought about it that much.
Message 9 of 13
(3,369 Views)
See if this can give you some ideas.
It would be even easier to place all words and their count into a map (try it!).
NOTE that you should set the keyword control to "limit to single line", else a linefeed might sneak in. You might actually want to verify that only a single word is entered (not shown)!
Message 10 of 13
(3,340 Views)
