How much is a char in a string
my approach to count how many times is a character in a string.
Faster than other methods, as with "Match pattern + loop" or with "Search and Replace"
Message 1 of 27
(4,564 Views)
I tpyically don't believe claims of "faster" or "slower" unless I see some benchmarking code and benchmarking results. 😄
Message 2 of 27
(4,559 Views)
For a string of 8M chars, search&replace is 15% faster. (67ms vs 82ms). Make sure to wire the character to both the search and replace inputs.
Message 3 of 27
(4,555 Views)
Message 4 of 27
(4,552 Views)
I am very suspicions about your benchmarking code, you compare apples to oranges: remove all these terminals from inside the loop. Watch out for constant folding. If all inputs ot a function are constants, it might get calculated only once and reused for later iterations, giving you a false very fast speed.
For small strings like in your example, performance is irrelevant, so do it once with a 8M long string input instead. Here you should see a difference.
Here is some code that is 8x faster for a 8M string input:
Message 5 of 27
(4,548 Views)
oops, a mistake ... the error clusters inside the For Loop  Smiley Embarassed
Message 6 of 27
(4,546 Views)
Here's a quick comparison of a few methods. There are probably even faster ways.
Message 7 of 27
(4,537 Views)
I redid the test with a string of 10e6 char
I confirm your results, your "count-method" is the fastest
"There are probably even faster ways" ...
Faster Than the count-method (??) ... with assembler and a Call Library Function ?
I'd be interested to know how to do that, really.
count : 20 ms
replace : 88ms
spreadsheet : 134 ms
(Q6600 Core2 Quad 3GHz- XP sp3)
I learned something today  Smiley Happy  (about how to do properly a benchmark test)
thank you altenbach
Message 8 of 27
(4,523 Views)
count : 10 ms
spreadsheet : 43 ms
replace : 49 ms
When the substring to search is longer, the best method will not work.
Spreadsheet time seems to depend on the number of matches
Lenovo w520 (i7, 8GB, win7 64bit)
Message 9 of 27
(4,506 Views)
not better  Smiley Frustrated    with asm  (call dll library)
count : 21ms
asm : 29 ms
Message 10 of 27
(4,487 Views)
