manipulate array
In the attached VI, is it possible to save the original array and scanned array like the image shown?
Thanks for your help.
hiNi.
(3,928 Views)
hiNi.
Yes.  Just do some formatting of your 2-D array before using your Write to Spreadsheet File.
You don't need your stacked sequence or local variables.
(3,922 Views)
Can you offer more insight?
hiNi.
(3,910 Views)
You've already got the writing of your initial array working.
All you really need to do to get your desired output is add your scanned array to your original array as additional columns.
Here's an example:
Note that because LabVIEW only uses square arrays, you'll end up with some extra zeroes.
If you really want nice formatting of your csv, you'll have to write your own function for writing the output file.
(3,904 Views)
Accepted by topic author hiNI
All you need is write a four column array for the first N lines, and then the remaining two column array. Do these in text in order not to pad with blanks. Here's a quick draft that seems to do the job (LV 8.5). Modify as needed (formatting, delimiters, etc)
(3,893 Views)
THANK YOU!
(3,879 Views)
