How to put SPI lines of NI-8452 into HI Impedance State?
When NI-8452 module is first connected to the USB port of the computer, the SPI lines and Chip Select (CS) lines are in High Z state. After that we initialized SPI, do the communication and then close the SPI using ni845xclose function. When ni845xClose function is called, I expected the SPI lines lines and CS line to return to its initial high impedance state, but it did not do that.
My question is: How can I put SPI lines back to High Z state?
Jeet
(2,629 Views)
Hey Jeet,
Check out this KnowledgeBase article:
http://digital.ni.com/public.nsf/allkb/CC435028E71BE6988625751A0063EA1F?OpenDocument
It looks like if you are using the Basic API the lines do not go back to their high impedence state when closed.
Hope This Helps,
Doug B
(2,616 Views)
