How much of Samples can a Vi generates
The graph takes a while to refresh.
This is why I suggest you to reduce the number of point you display.
Anyway, your eyes cannot see the difference between all of them....
Run with less point and then select your graph and try to move it with the mouse.
every time you do, you force the graph to redraw which takes a considerable amount of the processing power of your 2D video card. depending of your video card, it can take forever.
Benoit
Message 11 of 15
(1,120 Views)
Hello Sir,
How to Reduce the points...?? but I need 1 minute data
Message 12 of 15
(1,115 Views)
Keep your data in a variable (shift register, global, getset*functional global*)
Then only display a certain amount of those point, let's say that you cannot display more than 1000 points depending of the resolution of your screen and area of your graph. So parse all your data in a for loop and accumulate in a shift register only enough number of point to represent all your graph. let's say that you show only 1 point on every 1000 points.
Benoit
Message 13 of 15
(1,112 Views)
Hello Sir,
K Sir Thank You Ill try it Once
Message 14 of 15
(1,107 Views)
Benoit
That reminds me of the "Displaying Data" section in
Memory Management for Large Data Sets
http://zone.ni.com/reference/en-XX/help/371361M-01/lvconcepts
/memory_management_for_large_data_sets/
there's a demo contained in:
Managing Large Data Sets in LabVIEW
http://www.ni.com/white-paper/3625/en/#toc2
Message 15 of 15
(1,094 Views)
