How program for-loop to calculate RMS with window length of 100 samples and window step of 1 sample
Hi Jack,
read the context help for the PtByPt-RMS! That explains all the magic...
No, you don't need a SubArray function or whatever!
Message 11 of 21
(2,974 Views)
Assuming you already have an array with all the data in it, you could try having two for-loops [one inside the other], (one that goes up to 4901, and the inside one that goes up to 100,passing a starting value of the array X to which will receive up to X+100 samples to get your rms), using the Iteration numbers within the loops as reference.
Let me know if this idea helps,
Miguel V
Message 12 of 21
(2,971 Views)
Sorry... I have read the context help for the RMS ptbypt and I can't understand how the X input (signal) to the function changes for each interation... It is processing consecutive blocks of 100 samples...e.g block 1-100, 101-200, 201-300, etc, ct
Ohhhhh!! Hang on.... When the vi runs, the 2nd loop will not calculate the RMS until 100 samples became available, once the first 100 samples are available and the RMS is calculated, it will then update the 100 sample sequence (when the 101 sample is available) by dropping the oldest sample (i.e. sample 1), and adding the most recent sample (i,e, sample 101), providing an updated sequence on with the RMS calculation is performed...
Is this right? So all I would need to do is wire my 5000 sample signal straight through to the X input of the RMS ptbypt, which would be inside the for-loop (as you have it the 2nd loop above)?...
Now I feel stupid...
Message 13 of 21
(2,969 Views)
That is right.
You might have to throw away the first 99 values from the output array, depending on your requirements.  The for loop will output something regardless and you won't have a completed 100 sample RMS until the 100th iteration.
Message 14 of 21
(2,964 Views)
So the RMSptbypt will output values for any sample length, up to the sample length defined in the function.... So if I set the function to calculate the RMS over 100 samples, I will still get a value for any sample length between 1-99 samples?
Is that is the case I think it would be easier to use the subarray function to get the samples of interest so that I known than the output values form the RMSptbypt function directly match which the sections of the signal I am interested in.... I will nee tosynch these RMS values with other signals (e.g. force/strain), which will be mean dropping the first and last 50 sample from those signals...Using the subsarray will permit easier synching.
Jack
Message 15 of 21
(2,944 Views)
So you are now looking for something like this?  I scaled it down to test it.  You would change the 10 to 100.
Message 16 of 21
(2,946 Views)
Hi crossrulz,
Your solves my problem... I made a couple of changes to include the window length and step length in the calculations...
Many thanks,
Jack
Message 17 of 21
(2,926 Views)
Accepted by topic author jcannon
I think what you really want is this.  You were shortening your window size and weren't stepping your windows position inside of the loop.  Also, use the Quotient & Remainder VI for integers.  It makes life a little easier.
Message 18 of 21
(2,918 Views)
Hi crossrulz,
This is brillant..!
Many thanks for your help!!
Jack
Message 19 of 21
(2,903 Views)
You can use the moving average program for that.
Message 20 of 21
(2,491 Views)
