How read cells from an Excel file?
I want to search in the first column of a Excel file a name and when I found it I want to read the near cells (same row but different column).
I try with the Activex but I don't found the rigth solution.
Can I help me, please?
Message 1 of 9
(4,079 Views)
Please post what you have did so far. That will help in finding out the exact problem.
Message 2 of 9
(4,075 Views)
You can use "read from spread sheet"
Message 3 of 9
(4,073 Views)
Hey giada,
Before you can use the read from spreadsheet file VI the data of the Excel file must be copied to a .txt file then using the VI mentioned when set to string you can perform array searches to the data
I shall write you an example to show the search aspect of your problem
Philip
UK Branch
===If this fixes your problem, mark as solution!===
Message 4 of 9
(4,066 Views)
Ok, thanks
Message 5 of 9
(4,059 Views)
Here's the comma spaced .txt file search VI it may be possible to copy the Excel file to a comma spaced text file using active X before performing the search
Philip
UK Branch
Message 6 of 9
(4,053 Views)
Sorry, but I have LabView 8.5.1.
Message 7 of 9
(4,048 Views)
Here it is I'm currently working on a way to convert the Excel file to a Text file
Philip
UK Branch
Message 8 of 9
(4,044 Views)
This will Search the Excel file for you
Hope this helps
Philip
UK Branch
Message 9 of 9
(4,023 Views)
