daq assistant: freezes labview
hi all i'm using the professional version of labview (8.5) which is on vista (32bit) and i'm trying to use the NI USB-6009 but everytime i try to add the daq assistant from the DAQmx palette present under Functions Palette>Measurement I/O it freezes labview. what i mean is that i select the daq assistant i drop it and then the functions palette goes away and if i try to click anything/anywhere in labview it just makes a *ting* sound. i did some searching and installed the 8.9 drivers but with no luck. any help would be greatly appreciated (as this is my first time using labview).
Dan
Message 1 of 15
(6,427 Views)
Could you try loading Measurement and Automation Explorer (MAX) and Creating a Task:
Let us know if this works please!
Message 2 of 15
(6,425 Views)
hmmm for some reason the measurement and automation (MAX) thing wont load up... just my luck :s
edit:
dunno if this helps but i have mcaffe anti virus
Message Edited by dannnyds on 08-04-2009 04:30 AM
Message 3 of 15
(6,420 Views)
It sounds like your installation of LabVIEW/MAX/DAQmx has some serious issues, are you able to reinstall the entire NI software package? Or better, format your development machine and start again?
Message 4 of 15
(6,412 Views)
i was hoping to avoid a reinstall but i'll give that a go, reformatting is not an option. if i was to do a fresh install are there any specific steps/procedures i should be aware of?
Message 5 of 15
(6,408 Views)
I would wait a few hours and see if any helpful forum members have other less time-consuming ideas!
Failing that, just do a standard installation of LabVIEW with DAQmx drivers, etc. This will (should!) install DAQ Assistant and MAX.
Message 6 of 15
(6,406 Views)
so i do a standard install of labview and then i install the 8.9 drivers right?
Message 7 of 15
(6,399 Views)
Standard install of LabVIEW should contain all the drivers you need, I am unsure what 8.9 drivers you refer to!
Message 8 of 15
(6,386 Views)
i did a fresh standard install and still no luck, could this be vista related?. i might try emulating xp and see if it works in that
edit:
just to clear up, i can make basic programs in labview with loops, knobs, charts etc and its only the daq assistant that i cant get to work
Message Edited by dannnyds on 08-04-2009 08:32 PM
Message 9 of 15
(6,368 Views)
Ok, now feel free to go to this page and download the NI-DAQmx 8.8 driver which will specifically add the DAQ Assistant. This will hopefully make your install of LabVIEW function fully. 🙂
Message 10 of 15
(6,344 Views)
