How realize drop and drag of object ?
Hi everybody,
I have a matter, I want to realize a VI who makes drop and drag of indicator like a gauge for example.
For this I used an event structure to manage the drop and drag. But the problem is that with this solution i must put the indicator in my program to set the properties node (visible or position).
So the number of indicator that i can drop and drag depend of the number of indicator that i declare in my soft.
I want to know if there is an other solution to do that.
Please find attached a VI to show you my objective.
(3,261 Views)
duplicate post
http://forums.ni.com/ni/board/message?board.id=170&thread.id=390367
Please stop creating lot of threads for same question. please wait patiently for sometime. Somebody will surely help you.
Thanks for understanding
Mathan
(3,256 Views)
Duplicate french forum: Glisser déposer indicateurs
Regards
Yann C.
France
(3,197 Views)
I'm trying to find examples of drag and drop when found this thread. I'm trying to understand the vi attached; but what I don't get is, how is the picture inside the cluster is assigned to the jauge/vumètre?
Anyone mind explaining it?
It doesn't seem that it has anything to do with the events. That got me curious on how was that done
Thanks 🙂
(2,981 Views)
