ctrl space keyboard shortcut locks PC
I would like to use a keyboard shortcut to displaty the quick drop dialog box. Unfortunately, when I press ctrl + space, it locks my computer.
Does anybody know if I can change the shortcut in LabVIEW (or Windows)?
thanks
(5,330 Views)
Hi L54,
To change the shortcuts in LabVIEW, go to Tools >> Options >> Menu Shortcuts.  There's a listing for Quick Drop under View.  However, this is unusual behavior.  Which version of LabVIEW are you using?  Have you installed all the patches?
Kristen H.
(5,306 Views)
Hello and thanks for teh answer.
I am running 8.6.1. Where can I download the patches?
Not sure if this is a windows setting or specific software, but ctrl+space has always been a shortcut to lock the computer on my machine.
I'll wait for your answer before I change the shortcut.
thanks
(5,285 Views)
Hi L54,
usually you use Win-L or Ctrl-Alt-Del to lock the computer when using Windows. Ctrl-Space is rather "uncommon"... You should check your computer for some additional software reacting on this special key combination!
Tricky question: How do you insert non-breakable spaces in your Word documents? (Standard key combination is Ctrl-Shift-Space...)
Message Edited by GerdW on 01-27-2010 03:24 PM
(5,280 Views)
I found the software that was doing that: screen pass.
thanks
(5,254 Views)
