How to AVG columns in 3d array
I've been running into a wall on how to do the averaging of this particular VI.
What I am doing is finding the like matches of column 1 which represents RPM, and then go ahead and avg the data in each corresponding columns....then kick out the data with only the 1 particular RPM pt. and not multiple pts (655 and not 655a, 655b).  See the attached VI on being able do to this with selecting the Max value.
For example:
RPM           Ch1               Ch2
655           5                     3
655           4                     3.5
654           3                     2
653           3.5                  1
653           3                    11
653           2                     7
Help would be great thanks.
(3,758 Views)
Here's the Max Value Readings vi with actual data within the arrays.
(3,757 Views)
Accepted by topic author jonathanupr
Here is my seat-of-the-pants version.  I couldn't open your VI on this machine, my example finds matches in Col 0 (your col. 1) and finds the average and max values in the other columns.  Please check for errors.
(3,741 Views)
looks good.  thanks
(3,707 Views)
