How to Copy Excel Columns insert another Columns
Hallo,I try to copy Excel some range column,use insert copy column method add an the same column
How can I do use Labview?  (PS...I English so bad)
如何複製指定的範圍欄位,並使用插入複製儲存格方式插入一欄一樣模式的欄位?
(4,580 Views)
Hi fong_ui,
see this example http://zone.ni.com/devzone/cda/epd/p/id/4523. It shows how you can write data in a specified location. If you change the range property to read you get the data of this field. Hope it helps.
Mike
(4,552 Views)
For more information and some sample VI's and tool kits, you can go to the excel board
Joe.
"NOTHING IS EVER EASY"
(4,543 Views)
3Q ALL answer,but it is not I want
I do't Insert data to cell
I want copy some columns and use insert copy cell Function insert a new the same Columns
See following EX:
http://images.nike.tw/20070108/1208231796.JPG
http://images.nike.tw/20070108/1208231881.JPG
http://images.nike.tw/20070108/1208231916.JPG
(4,531 Views)
Hi fong_ui,
if you first use the example to read data from a range of cells and insert this copied data to a new range of cells, i think it is what you described.
Mike
(4,525 Views)
YES it is I want
3Q again
(4,517 Views)
Hi fong_ui,
here is a little example for you. Hope this helps.
Mike
(4,504 Views)
