gprs coordinates
Can any one help me out  to polt  GPRS coordinates in picture box.
(3,166 Views)
You need to be a lot more specific on what you want to do...
________________________________________________________
Use the rating system, otherwise its useless; and please don't forget to tip your waiters!
using LV 2010 SP 1, Windows 7
(3,154 Views)
Are you sure you don't mean GPS? The GPRS protocol doesn't have coordinates,
unless you send some...
Anyway, for GPS, if your device supports NMEA183 (most devices do), simply
read the serial port (it is working at 4800 baud, no parity, do
handshaking). Use VISA so it stops reading when it encounters a \r (or \n,
not sure). Then, parse the string. Use Format From String for that.
Wiebe.
(3,120 Views)
