How to Create Digital Array?
Hey everyone,
Right now, I am trying to create a digital array several thousand samples long full of 0's - I am planning to write over them with 1's at specific points so that I can create a digital waveform.
Is there any function or set VI on labview that I can use to create a digital array?
Thanks a lot,
Mitchell
Message 1 of 23
(4,824 Views)
What do you mean by digital? Do you simply mean that your values will consist of only 0s and 1s. LabVIEW does not have a bit array. You can create an array of Boolean values or a byte array. The Boolean array would be the closest to a bit array though internally each element will be an 16-bit value.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 23
(4,820 Views)
Use "initialize Array" from the array palette:
Message 3 of 23
(4,819 Views)
Sorry about that - yes, I do mean that the array should only consist of 0's and 1's - if I used initialize array, connect it to a number representing my samples, and connect it to a false boolean would that mean everything would start at 0 value?
Message 4 of 23
(4,810 Views)
There is only EITHER Boolean or Numeric to choose from. As Mark Yedinak said - using 8Bit Numeric will save you 50% of memory as Booleans are represented by 16 bits of data. In case you want to write the digital waveform to a DAQmx device - this works with U8 arrays. So you best use that.
Message 5 of 23
(4,797 Views)
Yes, initialize array can take a Boolean as it's element data. You could also use an 8-bit number as your data type.
Mark Yedinak
LabVIEW Champion
Message 6 of 23
(4,794 Views)
...as could be seen in the above attached picture of my first post:
http://forums.ni.com/ni/attachments/ni/170/689250/1/InitializeArray.PNG
Message 7 of 23
(4,790 Views)
Hi to all,
booleans are still stored internally as bytes - or did that change with LV2012?
Message 8 of 23
(4,787 Views)
not quite sure what you want, but you need a U16 to represent your several thousands value(65,536)...a U8 only represents a 255 value
Message 9 of 23
(4,779 Views)
Hi apok,
both Mark and comrade wrote "booleans are stored as 16bit values", which is wrong.
It's not about converting U16 to boolean arrays, it's only about how LabVIEW internally stores boolean values...
Message 10 of 23
(4,764 Views)
