How to Find CAN frame Receiving time
hi,
how to find CAN Frame Receiving Time Delay.
Message 1 of 8
(4,095 Views)
Hi Gokul,
delay to what?
Message 2 of 8
(4,062 Views)
Receiving CAN Frame Response time.
Message 3 of 8
(4,035 Views)
Hi Gokul,
CAN messages usually come with a timestamp.
So you know when you send them and you can read when you received the answer.
What's exactly your problem?
Mind to write more text in your message than just that?
Message 4 of 8
(4,028 Views)
hi,
I can't able to find timestamp in CAN Receive frame.please find the my code for your Reference.
Details:
Labview :2016
Diagnostic tool kit(UDS)
Send Commad: 10 03
Receive Commad:50 03 XX XX XX
i want time delay between TX and RX Frame using this tool kit.
Message 5 of 8
(4,003 Views)
Hi Gokul,
I see them in "default" CAN messages, like shown here:
Details:
It's the first time you mention that diagnostic toolkit: read it's help to learn about its options. (I don't have bought/installed that toolkit.)
Use "plain" CAN functions when you want to get their functionality…
Message 6 of 8
(3,999 Views)
i can't able to use default CAN Message because my architecture is already defined in Diagnostic tool kit only.
any other way using diagnostic tool kit find the response time.
Message 7 of 8
(3,992 Views)
See http://zone.ni.com/reference/en-XX/help/372140J-01/adcs/gettimestampvi/
Assuming you are using ISO TP (which the send and receive commands you mention appear to), the get time stamp vi should help you.  The Send Command is a SF, as is the receive command.
Also note that you don't need to use Diagnostic Service.vi for this.  You can use UDS Diagnostic Session Control instead (http://zone.ni.com/reference/en-XX/help/372140J-01/adcs/udsdiagnosticsessioncontrolvi/).  If you want to stay in extended diagnostic mode, you will probably also need to periodically send a tester present message (http://zone.ni.com/reference/en-XX/help/372140J-01/adcs/udstesterpresentvi/).
Message 8 of 8
(3,959 Views)
