Large data in network shared variables - Error 180121605
My main RT LabVIEW system keeps finding new ways to puzzle me.  I have a PXI-8106 controller linked via private network to the host.  The PXI runs the machine & collects data from short-run tests.  When the data is ready, the PXI packages it into a custom cluster as a network shared variable.  It sets a Boolean NSV flag to indicate that there is new data for the host to read.  Fine.
Some of the tests are now running longer, with data sets of 10-15MB.  Occasionally one or more data sets in a series fails to be seen by the host, although the PXI claims to have processed them as normal.  One of the few clues I have is Error 180121605 - 'OS and Network Services: (Hex 0xABC7005) Variable data is being written faster than it can be transmitted. This may result in data loss.'.  I am losing data.
I can see evidence of other parts of the system slowing down as the data is being handled, but I can accept this, as it occurs as a predictable time in the overall sequence.  What can I do to improve the reliability of data transmission here?
NSVs suit the use case - low priority, occasional use only.  I don't want / need to stream data to the host, nor do I want to develop my own protocol.  Any other suggestions?
Individual data points are queued at test run-time.  At the end of the test the queue is flushed, and the data packed into the custom cluster.  This is then passed into a queue within a functional global variable.  Elsewhere a low-priority loop monitors this FGV and passes the cluster to the NSV.  Running LabVIEW 2018, but had similar behaviour on 2014 also.  Processors are quite busy - 80-85% loading.  Plenty of memory available and the network is quiet.
Thanks all,
Ian
(3,292 Views)
Accepted by topic author IanDeaville(ZF)
Thanks all,
Ian
I can not speak to that issues since I do develop my own protocols.
Can you break up the data transfer into smaller parts?
I have read that NSVs are questionable under heavy CPU loads.
Ben
(3,282 Views)
You can try using the network queues to transfer your data. Use them like you would a LabVIEW queue. I haven't done a lot with data the size you mention but have transferred messages that were about 1MB. Our use of these queues is more ina publish/subscribe messaging system where we have small messages but lots of them.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(3,254 Views)
Ben, Mark,
Thanks both for your input.  It seems that I have reached the limit of reliability for NSVs, so I need to find another way.  I will look at options to divide the data into chunks - ideally as individual channels (waveform), with either a modified NSV or Network Queue process to pass them from PXI to Host.
Reducing CPU load would also be useful...I need to manage DAQ options differently for that...
Ian
(3,237 Views)
