How to Find Maxima and Minima for Each Column of a 2-D Array?
I have a 2-D array and I wish to find maxima and minima of each column of the 2-D array. Although I know how to get maxima and minima for the entire array but am not sure how to do it columnwise? Any ideas please?
Rohit
(3,397 Views)
Index the array inside a For Loop so that you find the maximum and minimum of the 1-D array.
(3,385 Views)
Hope this helps you.
(3,384 Views)
You do know about auto-indexing, right? What happens if the array is 5 columns?
Auto-indexing a for-loop that has the Array Max and Min function is the way to do it. However, you will need to transpose the 2D array before you auto-index since LabVIEW will auto-index by rows, and you want o index out the columns.
(3,380 Views)
Accepted by topic author rohit.2691
hi,
@Smercurio-What you said is right, i should have shown it using Auto indexing enabled which is really great option. I just tried to show in a very simple way.Smiley Wink
 Anyway here is the best way
(3,374 Views)
@ GITA_A, Ravens Fan & smercurio_fc
Thanks for your replies. It works well now.!!
Rohit
(3,348 Views)
