How to Get One type ref?
Hii
 In my Front Panel i am having 10 Boolean Controls , 5 String Controls and 3 Numeric controls ....  in that i want to take the 10 boolean control ref alone is it possible....................
(3,622 Views)
Do you mean you want one reference for all 10 boolean controls or would it be OK to put them in an array or a cluster?
-Matt
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
(3,617 Views)
Yaa it can be an array of Boolean Ref
(3,614 Views)
Hi Karthikey,
The following code should help you:
Ton
Message Edited by TonP on 02-24-2009 08:02 AM
My LabVIEW Ideas
(3,604 Views)
Hii
Is there any difference between the attached two methods of obtaining the Boolean Reference...
(3,568 Views)
KarthikeyanMathialagan wrote:
Hii
Allmost not.
The little difference is how you obtain the reference to the pane. In the 'Alternate Method' you get a reference to the VI by path. This will not work for VIs that are spawned.
Spawning can be done by setting the VI to reentrant, in that case the boolean references will refer to booleans on the edit-VI of the reentrant VI, the second spawning method is loading the VI into memory from a template (VIT).
Best is to use the 'This VI' reference:
Ton
My LabVIEW Ideas
(3,559 Views)
