UI window design of load vi inside vi
Can LV do UI windows as attached. Like the son vi windows opened inside the parent vi windows.
Thanks.
(2,596 Views)
Yes this is possible,
I imagine you want to limit the windows of the sub-vis to stay inside the owning VI.
in two ways:
Make direct OS calls to create parent and child windows. I think the GToolbox has code for this.
Or you could create your own implementation, with an XControl owning a Subpanel.
Here is some code that does this.
Another way is to poll the window position and alter that to stay inside the owning VI.
Ton
My LabVIEW Ideas
(2,589 Views)
