where can i find the niscope_32.dll file?
Hi:
 the problem is like this: i used the scope function in my program, then i made it into a executable file . but when i copy in to another computer and run the executable file , it need to load the niscope_32.dll file
but where can i find the niscope_32.dll file?
(4,173 Views)
Accepted by topic author ylongwu
You shouldn't simply copy the exe to a new pc. You should create an installer that not only has the runtime engine, but the NI-Scope driver.
(4,169 Views)
thanks very much  !
I  will have a try
(4,165 Views)
thanks very much! the problem has been solved
(4,148 Views)
Please mark Dennis knutson post as solution so that it will help others who run into same kind of situation
(4,146 Views)
