where can i find the niscope_32.dll file?
Hi:
 the problem is like this: i used the scope function in my program, then i made it into a executable file . but when i copy in to another computer and run the executable file , it need to load the niscope_32.dll file
but where can i find the niscope_32.dll file?
(4,179 Views)
Accepted by ylongwu
You shouldn't simply copy the exe to a new pc. You should create an installer that not only has the runtime engine, but the NI-Scope driver.
(4,175 Views)
thanks very much  !
I  will have a try
(4,171 Views)
thanks very much! the problem has been solved
(4,154 Views)
Please mark Dennis knutson post as solution so that it will help others who run into same kind of situation
(4,152 Views)
