How to Match Y-Axis Markers for Both PLOT 1 and PLOT 2
Hello:
See attached VI and Screen Shot.
The VI has two XY-Charts that have the same Y-Axis properties, However, the plot's vertical markers do not line-up.
Is there a way to programmatically correct this? I need the vertical axes to match so that I can use Y-axis labels from one chart for both charts.
I tried doing it using LabVIEW code shown in the last sequence frame but with no luck!
Thanks for any help/advise
Anthony L.
(2,003 Views)
Accepted by topic author Anthony_L
Please ignore this question. The right chart was reversed (inverted) in scale while the left chart was not.
(1,974 Views)
