How to Modify the VI documentation dynamically
I can able to modify the VI description dynamically using VI property node (Desc – string type). I want to modify help tag and help path also through programmatically.
How can I do this? Please help me.
Nesara
(3,497 Views)
There is a property node called Help which have two suboptions, Document Path and Document Tag. Hope it helps.
(3,481 Views)
Accepted by Nesara
thank you very much nitin
It is working
(3,467 Views)
Could you please mark Nitin's post as solution to the problem and not your post. You can unmark from options menu in ur post.
(3,462 Views)
