How to Modify the VI documentation dynamically
I can able to modify the VI description dynamically using VI property node (Desc – string type). I want to modify help tag and help path also through programmatically.
How can I do this? Please help me.
Nesara
(3,455 Views)
There is a property node called Help which have two suboptions, Document Path and Document Tag. Hope it helps.
(3,439 Views)
Accepted by topic author Nesara
thank you very much nitin
It is working
(3,425 Views)
Could you please mark Nitin's post as solution to the problem and not your post. You can unmark from options menu in ur post.
(3,420 Views)
