How to Process 2D Array String
Thank you for responding,
You have TRUE wired to the fract/exp string to number function. Change that to FALSE and see if it helps
This step did work, thank you so much.
@altenbach wrote:
The boolean array will be TRUE for all array elements that are in the range defined by the limits, and zero otherwise. Converting that to numbers (TRUE:1, FALSE:0). Multiplying that with your data will zero all elements that are out of range and leave the others untouched.
But for this step, the one that I need is, the elements inside the range will turn zero and the element outside will be untouched. But after I make the program you showed, it's the opposite.
Thank you,
Regards
Jenni
Message 11 of 19
(2,848 Views)
Thank you,
Regards
Jenni
Insert a Not function on the boolean array.
Qestit Systems
Certified-LabVIEW-Developer
Message 12 of 19
(2,844 Views)
Thank you for your reply
Where do I have to put the not function?
I put not before Boolean to (0,1). But the result become like this
Regards
Jenni
Message 13 of 19
(2,824 Views)
If you exclude the "in range" values, you need to multiply with the original data, not with the coerced values:
Message 14 of 19
(2,816 Views)
Yes, but all of the data become same as threshold value
did I put not gate in the wrong place?
Message 15 of 19
(2,808 Views)
Look again at my code right above. Did you multiply the raw or the coerced values with the 0,1?
(Don't use the orange output of "in range and coerce" or you won't have much left.)
Message 16 of 19
(2,805 Views)
It did works,
Thank you so much
Jenni
Message 17 of 19
(2,798 Views)
deleted…
Message 18 of 19
(2,782 Views)
Accepted by topic author jennichrni
Of course there are many ways to do all that....
Message 19 of 19
(2,743 Views)
